T&O flywheels
Post Thu Oct 13, 2011 5:00 pm
T&O flywheels
hi guys, today i finally got around to mocking up my flywhels assembly for the wl/kh and have a problem.
the pinion shaft and the sprocket shaft dont 'stick' through the wheels enougth to allow the nuts to do up properly ! anyone else had this problem ? sat am taking the bigend pin over and see if that fits properly.
Post Thu Oct 13, 2011 6:42 pm
Re: T&O flywheels
Do you have the proper keys for them? Did you try them without the keys? H-D keys are specific and not generic, so if the proper one is not used it will sit too high and not allow the shaft to seat!
Post Fri Oct 14, 2011 1:02 am
Re: T&O flywheels
hi robbie , yep with and without keys just the same , only 1/2 to 3/4 of the nut screws on .
have some used shafts here will take over later ,seem if its the shafts not the wheels
