Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties Speedo cable removal
Post Thu Oct 20, 2011 12:25 am
Should I be able to pull the inner speedo cable out from the rear wheel end in order to grease it up?
Or do I have to take off the speedo and remove the inner cable from that end?
Post Thu Oct 20, 2011 7:58 pm
Also, is there anywhere that sells the little speedo drive gear that goes on the drive unit on the end of the speedo cable?
Or do I have to buy the whole unit?
It looks like my Dad at some stage over the years pressed a plastic gear onto the turned down remains of the original steel gear. Now the plastic gear has stripped.
Post Thu Oct 20, 2011 11:25 pm
Post Fri Oct 21, 2011 4:28 am
kurt sold them at 45parts depot ,might have to wait a bit...
