Board index Flathead Power-Technical Questions, Answers, and Suggestions 45 Flatties WLC Throttle Cable
WLC Throttle Cable
Post Thu Aug 25, 2011 6:34 pm
Hey guys i own a 43 WLC ( dressed as a civilian (for now).. What is supposed to be holding the throttle cable so the outer doesn't rest on top of the head ??? . If someone is in restauration mode a pic would be nice Thanks... Frank
Post Mon Sep 05, 2011 8:59 am
Hi - I believe you'll need a head bolt with a screw thread on the top, so you can fit a clamp to hold the cable outer.
Should be easy enough to find or make a clamp. Don't know about an authentic one, but you need to fix the cable to get a consistent angle to the carburettor.
