Wed Jun 29, 2011 2:28 pm by greg1
I know this vintage bombsite is the best thing since bottle soda in my opinion .I suggested what has been proven over and over by myself and fellow employees at the shop ,Since Mark has the good fortune of both linkert brass bodies and this unique venturi being brass I feel my best proven method to securely locate the ventura in bore with no chance it will vibrate in turn damaging his fuel nozzle.Install ventura as well as fuel nozzle to be sure of perfect fit of nozzle installed in ventura.Lastly from choke end of carb pass a proper length ,for job,of silver solder through length of bore.Then use small professional grade solder pen to flow aproxx I/8" line of sliver solder smoothy between brass ventura and brass linkert body,duplicate exact process center of linkert bore roof smoothly flowing in minor amount of silver solder.
I will say even give the information that every member of this forum silver solders items together on a daily basis my first hand experience (not just reading about possibility method may work)has proven numerous times over the last 3 decades silver soldering brass to brass foolproof at least for 30+ years using method.If any forum members is a professional plumber or alternately has enough experience it's pretty easy especially with brass to flow your silver solder into pieces needing connected.And with no attempt of brag meant I can flow silversolder that with closed eyes you could easily pass over flowed solder with a finger and not identify location.
