crank pin ??
I finally was able to obtain all the parts for my WL/KH engine build, got the mockup engine out of the frame. Tore it all down, inorder to begin working on the assembly.
BUT, what I thought I had in the past bought ... well turns out I did not. and my memory was not as I had hoped.
OK, here is the gist of the issue:
Does three hole crank pins offer a vast improvment over the 2 hole ones?
I thought that I had three hole crank pin, but I don't.
For better bottom end oiling/long life should I get a 3 hole crank pin, to replace the 2 hole one that I have?
OR just go with the 2 hole one I have.
