WL crank pin 348-29 type 3
helsingborg
Post Fri Mar 11, 2011 1:02 pm
Any of you guys know a souce for the universal crankpin (1929-1973) part number 348-29 type 3, the one with two oil holes and works in all 29-73 flywheels? I'm trying to help a friend with his build and the oil hole in the right flywheel doesn't line up with the oil passage in the crank pin. Thanks in advance.
Elffors
Post Sun Mar 20, 2011 1:09 am
Re: WL crank pin 348-29 type 3
Guessing by your nic, you live in sweden as i do.
I've had the same problem and when i left my crank in for balancing at ormen's hd service he discovered this problem and supplied me with the correct crank pin. now i have my old crankpin and the original crank pin. you could either have my 2 left over crank pins for free or call ormen and he will gladly supplie you with the correct pin.
helsingborg
Post Sun Mar 20, 2011 7:50 pm
Hello Elffors. I just sent you an e-mail.
Karl.
