Engine idle Way too high when starting her
Was so happy to rebuild by 45 today as I had an issue with my gear box.
Spend my afternoon today to rebuild her.
Really looked forward riding her again after three months, but ain't this way.
First in order to start her up, I need to set the Linkert choke lever to almost close position, which was not the case before.
Before starting her, trottle lever on the handlebar is just slighty open.
She cranks up fine but the Engine idel is way to high, almost if I had turned the throttle to full position.
Same goes when I shut the choke lever to fully open position (even worse should I say).
Ignition is fine
Checked also the Linkert throttle lever that moves freely with the throttle on the handlebar.
My humble opition is that there is something going wild in the Linkert , that has been sitting there for three months , but cannot figure out what could go wrong.
Any idea that would help me get some clue to where to look at woudl be more than welcome.
Thanks!
