Throttle Assembly
dalaymond
Post Wed Jun 11, 2008 2:14 pm
Throttle Assembly
I'm using a set of ape hangers on my 45" flathead bobber.
The universal throttle assembly I have is a POS that I picked up from an antique parts supplier.
Is there a good throttle assembly out there that will would work well ?
Post Wed Jun 11, 2008 5:06 pm
Re: Throttle Assembly
Hi Dalaymond,
The H-D mid 70's throttle is not so bad, simple, 1"...
Post Wed Jun 11, 2008 9:53 pm
dalaymond wrote:I'm using a set of ape hangers on my 45" flathead bobber.
There used to be a great throttle reverse kit made by Anderson, who no longer is in business.
However I just saw a well used one on eBay. If I remember correctly cyclewarehouse had it.
indianut
Post Thu Jun 12, 2008 1:19 pm
When I built the tall bars for my 101 Scout Chopper I took a set of early 70's Sportster (they are the cheapest) bars, and cut off the end and welded it to the bars I was using. That got me Stock HD parts, Internal Throttle, and it worked real well.
VPH-D
Post Fri Jun 13, 2008 1:43 pm
The -74 throttle assemblies work well on bobbers/customs. They were used up until about 1981. Most of the aftermarket companies offer a replacement part, but I've seen some that don't open the throttle all the way.
VPH-D
