Unknown Lever Part
Post Mon May 12, 2008 3:23 pm
Unknown Lever Part
OK....... I know I took this off of a 45" at one time or another, at least I think I did, but ??, I can't remember what it is used for. Normal for me, heh. :wink: . Anyhow, I checked my jiffy stand parts, thinking it may go there, and it doesn't fit any jiffy stand I have. I checked linkage parts and I have not been able to fit it in on them either. I thought it may go to a right hand shift setup but I haven't found a reference for it there either. Over all, the part is roughly 1-3/4" with the bend included in the length. The rectangular hole is 17/32" x 15/32". The small round hole is 3/16".Approximate distance between the rectangular hole and the round hole is 1-3/16". Angle of the bent area is around 30 degrees. Plate thickness is 1/8". Thanks, Pa
Post Mon May 12, 2008 4:07 pm
Re: Unknown Lever Part
Hi Pa,
Modified drum brake lever???
Does look a bit like the "stop" bit on a big twin side stand though...
Post Mon May 12, 2008 4:20 pm
check out part 13202-30A on the 45 Depot website
Post Mon May 12, 2008 8:15 pm
Thanks Guys. Does resemble Kurts part except for the missing u area. Pa
Post Mon May 12, 2008 8:19 pm
Isn't that where ya attach the spring for the jiffy stand?
Post Mon May 12, 2008 10:40 pm
Chris wins the prize! That is a spring mount for the jiffy stand. The early type. Later ones had two ears to keep the spring centered and help eliminate accidental lowering of the stand.
Post Tue May 13, 2008 5:47 am
When you say early type.....pre 1941 ? Pa
Post Tue May 13, 2008 7:52 am
huh?? that is Lobby Ludd and I claim my £5.....
Post Wed May 14, 2008 3:07 pm
Well........ I tore an oem jiffy stand apart to get a better look at the lever on it. The casting number on the jiffy stand I tore down is 418-32. As you can see, this lever looks nothing like the one I previously posted. The angle of the rectangular hole is different as well. The distance between the rectangular hole and the round hole centerlines is approximately 1-1/4". The rectangular hole measures 17/32" x 15/32". The round hole is 1/8". Pa
Post Thu May 15, 2008 5:35 am
I have never seen one that looked like that PA.
Kurt
Post Thu May 15, 2008 6:29 am
Honestly from the way it's beat up, it looks to be a modified later one........maybe it was damaged and the owner couldn't find a replacement.
Kurt
Post Sun May 18, 2008 6:53 pm
Post Tue May 20, 2008 12:22 pm
It sure does Chris. Who ever had the jiffy syand I took it off of may have substituted it for an original jiffy stand spring lever. This may also explain why the one side looks to be worn off. Pa
milwaukee belle
Post Tue May 27, 2008 12:57 am
i already seen the same part on a 45' ....
but sorry : can't remember on WHAT exactly .
but the only one thing who hurt me is the rectangular hole instead of a common square one ....
about the first pics : i don't believe it is a 45' part ( coz of the rect. hole )
the second one ... i have no comments about it . :oops: maybe handmade ...
milwaukee belle
Post Tue May 27, 2008 1:02 am
pohlman's pic . it's a 1930 model .
Post Tue May 27, 2008 6:18 am
That looks more like it ! Reach into that pic and unscrew the nut. Maybe rectangular fit is under the nut ? Pa
milwaukee belle
Post Tue May 27, 2008 8:27 am
i don't know .... :oops:
