Crankcase Plug Identification
• Page 1 of 1
Ever see one of these crankcase plugs ? It is an expansion type. Pa
Re: Crankcase Plug Identification
Pa wrote:Ever see one of these crankcase plugs ? It is an expansion type. Pa
Pa, Yer link sez,
You do not have the required permissions to view the files attached to this post.Pa
That's strange Chris. I can see it. I tried to put it up over at imageshack but the upload link is down for now. I try again later. Pa
Finally got Imageshack responce.
It is an aftermarket automotive item.
Thanks Chris. I found it in a servi car timing plug hole. What could one have used it on in the automotive side ? Oil drain maybe ? It is to small to be used anywhere else. Pa
PA,
It looks like an aftermarket expanding plug for the drain hole in a small boat.
I keep Dorman examples in stock for stripped tranny plugs.
i have seen thousand same kinds in a BOAT shop !
• Page 1 of 1
