A plee From Fellow Bikers
Heck Scoot....Curt couldn't have made it so pretty without you sending it along to him. Thanks Man ! Thanks for the rocker box too ! I just got it in from Indianut today and he did a mighty fine engraving job on it. Thanks Indianut !! Another great artist among us Fella's !! I will post pics of it as soon as I get the polishing done on her. I plan to lay out all the components loosely and shoot a few pe-assembly pics for posting. I will post complete assembly pics also. The head hasn't come back yet. I'll check on it this weekend. These parts, along with all the awesome hardware Johnny had shipped to me, the great looking pushrod covers Curt sent, the head Amklyde sent, the gaskets and tappet block Jim sent, The blasting/welding that Wayne is doing, and everything else others have done or are doing that I've neglected to list are making this Urn one BEAUTIFUL work of Humanitarian Art !
I had not really read this untill now. It is very sad.I know the base was mentioned earlier[pg.1].I have a piece of 7075 aluminum 8"dia.X2 3/4"high.Capability to bore a hole for the cylinder flange and polish the surface finish.I think it would be heavy enough for a good base.If you would like it just say the word.
Indianut...I was waiting for the polish work to be completed on the rocker box before posting an update, but here is what is going on at the present. Polishing of the rocker box was to be completed today but power was lost until 2:30AM EST due to heavy thunderstorms. The head has been initially sand blasted for the weld prepping and it is now at the welders. Finish bead blasting is scheduled for today [Wednesday]. ETA on it's return is Thursday. I should have more pics for you folks then. Still no block of the ordered aluminum. I am getting impatient with that and I may go elsewhere for it. Glad the order for the stock was C.O.D.. If it shows up after I get a different chunk, I will refuse it. I will be chatting with a local shop sometime tomorrow in regards to another source. This shop will do the mill work on the block also. Even though I have the rough dimensions for the tappet block to the cylinder, I want to do an assembly mockup for verfication purposes before the shop puts a cutter to the aluminum block. Pa
Update.............Head welding is completed but finish bead blasting may take a few days more. Rocker box polishing particially completed. Polisher is having a heck of a time in the crannies and he won't be satisfied until he gets more of them glossy. Awaiting base stock report from machine shop. Should get a call tomorrow on it. Hardwood not acquired yet. I want to see the machined base first. Hang in there folks !! Pics are coming.
Got the head back today fella's. Pics are below. Wayne had to leave for the DC area. His son is getting a brain operation in the morning. Surgery should take 7 hours or so. They are gonna try and seal off the bleeding that keeps causing the young man strokes. If it all works out ok, he won't loose to many motor skills. Wayne is a tough old Bro. I don't know if I could get through what he is going through.
Polishing on the rocker box is still in progress. I should hear something on it in the next day or so.
Base material is in. Machining of it is awaiting assembly mock up. Pa
Yeah...he did a nice job on it. I will get a tappet block pic up in a few days or less alnong with a rocker box pic before it was polished on. Haven't got the rocker box back again yet with the finish polishing but I will post Indianut's engraving work on it then also. Many more pics to come soon !! Stay tuned Fella's !!!!! Pa
Urn update............ Block of aluminum is a no go fellas. They want 4 bills for the chunk and I won't give that much for a months supply of melted beer cans !! We are goiing to go with a slab of it instead. The slab wil be milled around the edges for appearance and one side will be deeper for the push rod covers. The needed cylindrical depth will be bolted on from underneath the slab tying in with the cylinder bolts. I am thinking stainless tubing capped off with a welded on stainless plate. Sorry for the delay guys but this base has been a nightmare !! Pa
