What's Wrong With This Front End???
Fatdog Vintage Salvage
Post Tue Oct 08, 2002 12:26 am
The rear leg looks ok! The front looks as though it has acquired some birth defects. The leg tubes look too short and the spring rods look too long! looks VL not RL
m/cgeezer1945
Post Fri Oct 11, 2002 12:19 am
Looks just like the one in my stuff... Left over from a pile of VL stuff I sold in 1992...Kept it cause I like it and plan to use it at some point..VL had a longer lower spring 13 coils instead of 11 if I remember right...I have the hub and brake assembly
with and H-D 21" rim laced up...but need rockers used them on somethin else...Geezer ps It is not 48, 30 to 36
JIm
Post Fri Oct 11, 2002 3:39 am
HOOTER
Post Fri Oct 11, 2002 4:36 am
Pretty well whacked already. speedo mount welded back on. Upper motor mount looks weird.
JIm
Post Fri Oct 11, 2002 11:40 am
There's more than that.
Post Fri Oct 11, 2002 2:27 pm
Sidecar loops. I would also be suspicious of the dark-colored area at the top of the seat post - frequently cracked, also bent/hammered for pan clearance.
Want stroker flywheels for your H-D 45? Click here.
Post Fri Oct 11, 2002 3:43 pm
Floorboard mounts, Key for a knuck?? rear tank tabs stuck on, yeah, she's pretty stock.
Be a shame if it was actually a straight leg pan that's been all hacked up.
[This message has been edited by Frankenstein (edited 11 October 2002).]
Jerry Wieland
Post Fri Oct 11, 2002 9:56 pm
Don't know for sure but I believe it is the remains of a late 54 or 55 straight leg pan frame. Jerry
JIm
Post Sat Oct 12, 2002 1:11 am
Bingo Frankenstein and Conan.
That was the first big thing I picked up on and it is also stated in the text. Along with the other added and hacked up parts.
Dead givaway that it is probably a hacked up Pan frame as Jerry says.
Frankenstein,
Did you get what I sent you?
Jim
[This message has been edited by JIm (edited 12 October 2002).]
Post Sat Oct 12, 2002 2:09 am
JIm,
yup, sure did, sorry 'bout that, forgot to get back to you. Thanks mucho.
The rest will be there for a while at least.
F.
HOOTER
Post Sat Oct 12, 2002 3:30 am
Oh! Didn't know we were trying to date the thing. Image
m/cgeezer1945
Post Sat Oct 12, 2002 3:58 am
Top motor mount is pan, 55 -57..Looks like a good frame for a chopper...Geezer
