Board index Flathead Power-Technical Questions, Answers, and Suggestions General Whatever-Technical Lightest tappet
Lightest tappet
Post Fri Jun 08, 2012 10:43 am
Is the three holed ,thin walled roller tappet used in KHK Models the lightest tappet made ? If not what is the lighest weight roller tappet made that can be used in a flathead ? Thanks. :D :D
Post Fri Jun 08, 2012 10:10 pm
Are you also going to have the lightest rider on the bike? :D
Post Sat Jun 09, 2012 4:21 am
You know Chris you touched on really a funny point , it does seem futile to have a lightened chrome moly frame ,titanium this and that ,everything drilled and lightend and then top it off with an over 200 pounder (and I am sadly understating the poundage in my case) . Kinda like putting a watermellon on top of a banana split instead of a cherry . Yes,in the event I try to set a record for the fastest flathead in the history of the known universe I will definitely not have my elephant sized butt in the saddle . Thanks again for your humor ,we could use more of this in our lives from time to time . Now back to the technical issue at hand , is there a lighter weight roller tappet than the thin walled three holed KHK tappet ? :D :D
Post Sat Jun 09, 2012 8:27 am
I know the subject is lifters, but extending it to other valve train components, I'm looking at some KHK valve train components on hand and find the weights as follows - lifters ~ 82 g, and IN and EX valves ~ 117 g and ~ 112 g respectively. I can't remember what you're using for valves, but when you go for the FH speed record of the universe, perhaps it might be easier and a more significant weight savings to go with titanium valves than it would be with a lifter change.
Post Sat Jun 09, 2012 11:53 am
Search the archives. Some years back one of the folks actually found an HD lifter that was lighter than the KHK lifter by a few grams. I think it was a late HD servicar part number, but I don't recall for sure.
Post Wed Jun 13, 2012 7:15 pm
Thanks for the responses I'll use the ironhead sportster tappets and drill them myself. :D :D
Post Mon Feb 25, 2013 3:35 pm
and you could try out these blanks for size
http://www.ebay.co.uk/itm/Titanium-Conn ... 3e5&_uhb=1
:D ,regards jib
Post Thu Sep 25, 2014 3:35 pm
WZ507, the weight of the KHK lifters. is that with or without the adjusters please?
Also, do you happen to know the weight and possibly have a picture of the 18220-53R drilled retainers for early KR and 53KK?
Malte.
