nut lock on crank pin, pinion ,sprocket shaft
Bent Valve
Post Tue Feb 07, 2012 4:42 pm
hi, im a newbie here.
I would like to hear your opinions on those nut lock retainers on flywheels..
I think loctite with proper torque, on clean threads and surface would be sufficient..
but what you think? i have seen a tiny screw and retainer were tumbling in breather bore before,, but flywheels were tight..that made me not want to install those retainers..
Post Wed Feb 08, 2012 6:52 am
Re: nut lock on crank pin, pinion ,sprocket shaft
Bent Valve, I'm with you. I also have found retainers wadded up in breathers. I have come up with a compromise. I use the retainers on BTSV mainshafts, smaller nuts, less centrifugal force applied to retainers, and just locktite to crankpin nuts. However, these are T&O flywheels with the larger crankpin/nuts.
Your call,
Post Wed Feb 08, 2012 7:46 am
Use the locktite on the lock washer screws.
Beachdog
Post Wed Feb 08, 2012 9:48 am
I've been using blue locknut on the retainer screws for 40 years. I clean the threads in the flywheel first with carb gum cutter, blow dry, apply locknut, assemble and wipe up any excess. No failures yet.
Bent Valve
Post Wed Feb 08, 2012 11:05 am
thanks guys,
