who can say
Post Wed Feb 03, 2010 4:19 pm
who can say
hi guys who knows what this is
http://cgi.ebay.co.uk/HARLEY-VINTAGE-BR ... 35a6cba795
cheers jib
Post Wed Feb 03, 2010 4:53 pm
Re: who can say
It is a Sportster switch.
milwaukee belle
Post Fri Feb 05, 2010 2:22 am
Re: who can say
yes ! :)
this one can also work on a 45' .
in facts : i believe it's the same part , except the cad-plating ....
Post Sat Feb 06, 2010 11:36 am
Re: who can say
milwaukee belle,the blurb with it says that its push not pull , ithought 45 type was pull?,
regards jib
milwaukee belle
Post Sun Feb 07, 2010 7:05 am
Re: who can say
OOOPS ! SORRY :oops: :oops: :oops: :oops: !!!!
i didn't knew this !
that's true : 45's is "pull-type" :oops: :oops:
( sorry )
thefrenchowl
Post Sun Feb 07, 2010 7:25 am
Re: who can say
Sportsters and K are pull as well, the pedal screw pushes on them at rest when fitted on left hand side, pull with spring when on the swing arm right hand side...
So the seller has got his blurb wrong... Same switch for W, K and XL...
Post Sun Feb 07, 2010 2:35 pm
Re: who can say
hi patrick, the blurb also says that there is ''no hole for a spring'' so i dont think it can be for a sportster then if they are all the same. two hours to go and no bids, reckon nobody knows what it is,
regards jib
Neil74
Post Sun Feb 07, 2010 9:49 pm
Re: who can say
My memory may be off, but I think my 75 FXE with stock mid controls used a switch like that one small tab on bottom of pedal hits switch. The spring was wound around pedal shaft.
Neil74
Post Mon Feb 08, 2010 7:14 pm
Re: who can say
Wow was I off, dug an old switch out an nothing even close to the same. Sorry, now where did I put those papers:)
