1927 JD Which is the correct carburetor
Post Fri Sep 12, 2008 2:55 pm
All the books show a DLX38 as being a 1927 only carburetor. I have a DLX38 and it has four screw flanges for bolting on a carb cover. The parts book shows this cover. Yet the factory photos I find of 1927's show the earlier type carb with the choke venturi.
Post Sat Sep 13, 2008 8:32 am
Re: 1927 JD Which is the correct carburetor
Chris!
That's certainly an "H" model (the airhorn is a spring-loaded valve; there was no choke mechanism, nor a venturi), which is certainly a curiosity since DLXs are listed back to '21 for the 74" H-Ds. And back to '15 for '61s.
However, I occasionally get requests to cut the 'horseshoe' 1 1/4" H float from J owners.
It wouldn't surprise me if commercial machines were often equipped with them.
Ironically, Indian models of the same vintages, such as the PowerPlus/Big Chief, are also often listed to have DLX carbs, yet many of those also are found with the large H installed. Deluxes may have been a preferred option.
There can be little doubt that you will find the DLX much easier to recondition and tune, and a much better performer as well. Most importantly, it has a bottom support!
Are you sure your DLX38 doesn't only have two airhorn screws instead of four?
The flange would be 'scalloped' instead of flat to allow air to enter.
