Board index Flathead Power-Technical Questions, Answers, and Suggestions Indians Chief trans bearing.
Post Tue May 20, 2008 7:45 pm
Chief 7207B clutch side bearing.Which way does this angular contact bearing go in? It has a brass retainer ring holding the balls.The trust side of the bearing's outer race has a wide rim.Is this in or out? Thanks,A.J.
Post Mon Jul 21, 2008 8:22 pm
The thrust side goes toward the primary (the widest gap between the inner and outer race will be to the inside of the transmission)
