Sport Scout Info needed
The Indian Runner
Post Sat Dec 01, 2007 8:22 am
Whilst I await my new pinion shafts for my bobber project, I was wondering if anyone could tell me the following standard Indian setup?
I am after the standard factory sizes of the following diamensions for the 45 Sport Scout.
-Valves, both inlet and exhaust, what size diameter where they?
-Inlet/exhaust port sizes into and out of the barrels, ie the internal diameter.
-Size of the inlet manifold nuts, ie what size thread do they screw to?
-And finally out of interest, the internal diameter of the throttle side of the Linkert 1-1/4 carb (downstream end).
I would like to know this info as it would give me something to hang my hat on so to speak as I continue to nut out what direction to go with my stroked 741 Bobber project.
Happy Riding,
IR :?:
Post Sun Dec 02, 2007 5:05 pm
Re: Sport Scout Info needed
IR!
The valves were 1 3/4" and the internal bore of the carburetor is 1 3/8" (excluding the venturi of course.)
I haven't a SS cylinder handy to measure the inlet nipples (Nearly everything was 24 tpi.), but the I.D. of the cast manifolds can vary widely.
...Cotten
The Indian Runner
Post Mon Dec 03, 2007 4:38 pm
Thanks a bunch Cotten,
This info is great as it gives me some idea just how much smaller everything was on the 741. I am not proposing to make this thing into an all out beast, but it does give me some sensible sizes to aim at where and if needs be.
I reakon I can easily push the 741 inlet manifold from its present 13/16th (approx) out to around 1.1 inches, but it will require a custom inlet manifold and a bit of thought for the way it is attached to the threaded nipple on the barrel. (Probably the easiest way will be to make up a threaded packer to take a larger manifold nut).
I have to nut out if I am going to retain the M741 Linkert or go for a bigger one. At the moment I am looking at keeping it and installing a 'Thirty Fifty/841 HDA', 13/16 venturi. One advantage with the limitations of the 741 barrels is that stroking them, smaller carbs are not all bad news as piston speeds are not increased and there is a longer time for the induction and exhaust strokes.
This is the reason why I am keen to find out the nominal internal size of the SS inlet manifold, so I can make a more informed decision in this area, so if anyone out there can measure an old barrel they may have lying around, it would be very much appreciated.
As I say, I am still at the stage where I have yet to take a deep breath before I decide in which direction I will move with all this stuff. I know that keeping it all 741 standard is the safe way to go, but thats not in my nature, especially as I used to have a little single seat race car...I just gotta fiddle!
Thanks again to all that have and continue to answer my many questions.
IR :lol:
