Thu Nov 01, 2007 7:53 pm by Johnmcmd
Well I finally found the problem with my M88, Bonneville venturi and nozzle, Ollie cam'ed '46 Chief engine: it was the nozzle. The engine ran rich at idle, came off choke very quickly, the low speed needle was unscrewed about 10-12 clicks out from a good idle, there was backfiring, starvation when opening the throttle, but ran well at speed. I played with ignition timing, float levels, mixtures, hotter plugs, etc. but didn't quite seem to get it running right. Turns out the Bonneville nozzle holes (.052") were letting in too much air too early when the throttle was initially opened thus leaning the mixture and starving the engine in transition. I went to a modified stock Chief nozzle (.043" holes and larger ID to increase flow). That may not appear as much of a difference but the results were immediate. First thing, the low speed needle went in 12 clicks were it belongs. Previously it had to be set too rich to compensate for the lean mixture in transition. Response was very smooth and seamless from idle through transition to speed: no stumble, hesitation, black smoke and any sign of backfire. An amazing difference! I pulled the plugs after a short ride and they looked almost new! I will probably go back to the cooler stock plugs since I don't have to worry about carbon fouling any more.
I'm not sure why the Bonne nozzle didn't work with the Bonne 1 1/8th venturi but it may have something to do with the design of the M88 Linkert . The original M88 used a main jet (now plugged), a 15/16th venturi and nozzle with only 4 holes instead of 5 like Indian, and they are very small (.038") and set lower on the nozzle. Clearly the M88 ran a much richer mixture in the nozzle. In any case, my experience with the M88 shows that while not a direct swap it can be used successfully with a souped up engine if you pay attention to the nozzle and transition problems. I want to thank Victory Library for their Linkert book which helped me diagnosed the problem......and probably saved me a bunch of money to unnecessarily replace the M88 carb when only the nozzle needed attention.
Johnmcmd
