Sport Scout stroker project
• Page 2 of 2 • 1, 2
Re: Sport Scout stroker project
Rocky,
Was is the prevailing wisdom on replacing the cam follower shafts?
Do they go in back to front ? front to back?
Heat and press?
I really don't want to screw this up.
jj
Heat and press?
jj
JJ,
The cases need to be split and the shafts are pressed out from the inside. You need to have the surrounding area around shaft supported before pressing out.
You need to hone the rockers to find the size shaft you need.
Installation is the reverse.
Rocky
1957S/VG
Rocky
1957S/VG
