Thu Feb 08, 2007 10:08 am by panic
I don't know if any Scout stroker pistons are available, if yes this makes the remaining choices easier as to economics: calculate what you need to get the dome to a good quench distance: piston CD + rod length + 1/2 new stroke should equal stock piston CD + 9.152" (stock 7.402" rod length + 1/2 stock 3.5" stroke).
If not, finding a piston is IMHO far the most important thing to do especially since not all engines will have the same shape - pop-up for Bonneville, etc.
The Truett wheels will probably be Chief (4.4375" = Scout + 15/16") stroke, use Sportster pin, and need a small base shim to get the stock distance back but this is not fixed yet, perhaps reducing the stroke to 4.402" to get the exact total height would be easier for most people. The reason for the XL rod is simple: all new stronger parts cheaper than rebuilding the original worn 60 year old parts.
