the story so far!!
panic wrote:I hate to ask, but are you sure that mag has the right firing order? Many Fairbanks were adapted without changing the point cam, with the thought "3 degrees is no big deal".
What is the exhaust pipe OD?
steve_blackbob wrote:epinut wrote:Any particular reason why you've mounted the gearbox tilted like that?
gearbox isnt fitted yet, it needs the bottom and top mounts narrowed to allow it to sit down between the rear frame rails and engine plates.
steve_blackbob wrote:epinut wrote: Wonder how much it's safe to remove?
i've got to take .25" either side out but the lug seems pretty solid, reckon you could take more than that safely.
how narrow do you need to go?
