Indian generators
I am building a bobber 741. I would like to run a 12 volt generator on it. Can you use a 12 volt HD generator? Does it spin in the correct direction? Does a generator care what direction it spins to generate? Or should i go with the VW generator? Anybody got a part number or something I can order from? And no, i don't want to run an alternator, unless it was cheap and could fit inside a Foster Lager beer can. Thoughts, suggestions welcomed. Thanks!!
