sportster magnito for indian
flattyflyer
Post Wed Feb 27, 2002 8:19 am
harley fires at 45 degrees. indian fires at 42 degrees. is it possible to grind the point can on the mag the 3 degrees? anybody seen a scintilla mag on a indian? would like to adapt a morrison mag for an indian from the oil pump location to where the coil or stock mag goes. anybody done this yet? i'm aware thet the stock mag mounting pad would have to be ground away or modified. i've got the morrison mag and would like to be able to adjust the valaves with out removing the mag if it was placed on the oil pump. lets talk shunk camss. i've got a 74" set and only 1 80" shunk cam. the profile is different. any gearhead indian people out there? only 1 hit on the indian site and it deals with 101 or sport scout heads. no disresect as this is also a worthy subject, but only 1 topic?
HOOTER
Post Wed Feb 27, 2002 3:36 pm
You could grind the 3 degees neccesary for the Indian timing but you may also need to build up the cam to keep the original dwell if you find that the points start burning up.
Since your new to the board, look at what you can click on, explore. You can bring up all the Indian topics easily. Have fun!
HOOT
[This message has been edited by HOOTER (edited 27 February 2002).]
Post Sun Mar 03, 2002 4:47 am
flattyflyer:
Morris sells a mag to fit in the distributor drive of Indian V Twins. If these are too pricey, check the archives of the Virtual Indian list illistrations of where to grind have been posted in the last year or two.
There are now two companies selling electrronic ignition conversions for Scouts and Chiefs. http://indianpartseurope.com/news.htm www.kingclutch.com
don
Post Sun Mar 03, 2002 5:53 pm
flattyflyer,
Have You read; http://home.t-online.de/home/pravg/dixie.htm
At the bottom of page, VII. Timing, And VIII. Some Timing Tips
don
Boogiemanz1
Post Sun Mar 03, 2002 10:03 pm
FF, try the address I gave Don http://www.magnetoparts.com/ maybe this guy can help.
