big block chevy stainless steel valves for indian
morrison big block chevy valvles for indian? JC Whitney 2.065? any bigger misses with the bore. PAW sells them look in the hotrod or automotive magazines. also if you are looking for a piston that is 60 over plus 0.05 a jeep six cylinder piston will work although it is a pop up piston and the skirt must be modified also some work on the piston pin bushings. after sixtyand a half thousands the pistons start again at thirty thousands
