linkert leaking
gmanm1
Post Fri Mar 01, 2013 12:40 pm
linkert leaking
i have installed a new bowl and everything in it including stainless steel needle valve , but the thing still leaks. it pours out the little hole when on side stand. is this just what you put up with to ride an indian or is there a fix besides going to cv carb.
Post Fri Mar 01, 2013 11:43 pm
Re: linkert leaking
Of course you can make the Linkert work. Cotten would be better to answer this but not setting the float to 5/16"- a float that doesn't and turning the float bowl the wrong way come to mind right away!
gmanm1
Post Sat Mar 02, 2013 6:06 am
Re: linkert leaking
i am sure that turning it the right way is also key , but where should the nut on the bowl end be. i have the one that has to be offset.
tomfiii
Post Sat Mar 02, 2013 11:25 am
Re: linkert leaking
Go to link ebay to see position of bowl also the fuel level has to be set different depending which float you use and slightly offset to clear where needle area at center of lower of carb comes down into bowl area.
http://www.ebay.com/itm/Linkert-Indian- ... 5f&vxp=mtr
gmanm1
Post Sat Mar 02, 2013 3:34 pm
Re: linkert leaking
thank you very much , i had mine all the way up against the side where it couldn't go any farther. i will see if this helps. i have the nitrofill float set st 1/4 and offset to the left 1/16 and all the way foward without rubbing the bowl
