Generator with Mag
A friend has a knuckle he is just getting running. It has a mag and a 65A generator with a Bosch and a battery eliminator. All the electrics work properly using a battery, but nothing works when it is running. I suggested polarizing the generator, and he had never heard of it. Is there anything else I may be missing about this combination?
Re: Generator with Mag
TRY POLARIZING IT. SHOULD GET THE LIGHTS ON. CYCLE ELECTRIC MAKES A GOOD GENERATOR WITH A BUILT IN REGULATOR. I THINK IT HAS A 2YR WARRANTY.
ALOHA, JD
ALOHA, JD
Thanks, JD. I have suggested both things and wanted to make sure that I wasn't missing anything as I have never used the battery eliminator setup before. I have a Cycle Electric in my own bike and it works great.
You don't need a battery eliminator. Simply use a pre 1970 XLCH 74511-65 or 74510-59 voltage regulator and the overflow capacitor
just curious, how do you polarize it without a battery?
john
john
john HD wrote:just curious, how do you polarize it without a battery?
john
With the engine running
hey folks,
i know this is a very old thread but i was wondering if there is a need for an overflow capacitor when using the Cycle Electric generator with built-in regulator? spoke to the folks at Cycle Electric and they said no, but just wanted to double check with you guys since i have a great deal of respect for the collected wisdom here.
btw, i will be using this on a 40 EL stroker engine, kick only, batteryless mag setup.
thanks!
-dan
thanks!
-dan
-experience is a wonderful thing. It enables you to recognize a mistake when you make it again.
The capacitor provided a little extra juice for the lights and horn on an XLCH.
VPH-D
VPH-D
great, thanks for the info.
-dan
-dan
VPH-D wrote:The capacitor provided a little extra juice for the lights and horn on an XLCH.
VPH-D
Actually it provided a steady flow of juice for the horn and lights when idling. But more importantly it kept the system from putting out too much juice and blowing light bulbs. Ask me how I learned this lesson.
I too learned the hard way. Use something to catch the excess from the gen. Lights were fairly cheap but the new battery and regulator cut into my beer stash real good. Cost more than a capacitor for sure.
Steve H
thanks for the replies guys! do any of you have a part number for this capacitor, or is it listed in the manual for the early sportsters as an "overflow capacitor?"
many thanks,
-dan
many thanks,
-dan
Parts book calls it a Horn Capacitor.
I can't find it in my '65 catalogue. Just another missing part from a H-D catalogue
found it, guys. it is:
32727-63 OEM
32-7784 V-TWIN
just for everyone's future reference.
take care,
-dan
32727-63 OEM
32-7784 V-TWIN
take care,
-dan
Re; steady power to lights at idle
I had a factory guy tell me 30 years ago that the dim light at idle problem was one of the reasons the mag CH was dropped.
Lawsuits resulting from accidents, that is. Dunno, but it seems reasonable.
VPH-D
VPH-D
VPH-D wrote:Re; steady power to lights at idle
VPH-D
The real reason was the 1970 Federal Motor Vehicle Safety Standards required vehicle headlamps to opperate for 20 minutes after the engine stopped. 1970 laws also required serial numbers on both motorcycle engine and frame.
I did not know that. Thanks for the info...
VPH-D
VPH-D
