Problem with warranty for New Knuckle
Had no luck getting hold the owner of FHP but ended up contacting S&S because they own FHP now. So I ask them about the warranty on the engine and basically they said too bad ,you are out of luck but they be happy take my engine and go though .But I would have to paid for them to do, man that suck.
So I took the bike over to the local S&S dealer at my cost to find the problem. Will we did the compression test 175 in both cylinders and then the leak down test found it to be leaking into the case. Pull the heads off and guess what we found? Well somebody at FHP didn't check the size of pistons they we're installing which were 0.010 too small for the cylinders and end gap on the rings was 0.025 that she was burning some much oil.
So this really sucks , nobody want to stand up to the warranty so I may never buy another engine from S&S again.
Thanks guys for letting sound off some.
Between a rock and a hard spot.
Steph
