Mon Jul 23, 2007 8:48 am by knucknutz
oil is pukin out vent holes and looked like it was drippin around where front cover mashes into rocker box and i could see oil beading up around some of the screw holes from the pressure and push rod covers where full to. i spent a lot of time makin sure covers fit tite,i ran these heads for years no problem,whats it matter where its pukin from ,its pukin.bike is also smokin bad. cases are std knuckle repleica cases and yes they have the right oil passages, i'm not that stupid to put motor together with wrong cases. i filled lifter blocks with oil on top of lifters and kicked motor over and oil cleared out and i could here sucking sound in blocks.i've put other knuck motors together and never had problems before, only real differance in this motor is bigger s+s pump.motor is std cases,s+s crank - pistons,s+s timing gears with reverse turning timer gears,s+s breather,andrews stock cam,jims .005 over lifters,tedd cylinders,rockers are tedd's,couldn't get a hold of fhp,2000i dyna ign. single fire.could rockers with brass groved bushings in them be lettin oil pass throught to fast,less restriction to hold it back than stock ones would? i ran a pump like this on last motor,which was put together by local ass@^%, and failed
after5000 miles and run pump strait with no plugged and drilled fittings and had no problem returning oil from heads,same heads as now,so i'm lost.
+s+
