47 knuckle numbers
• Page 1 of 2 • 1, 2
i havent been here in awhile,but i notice a lot discussion on numbers mine is 47fl 125xx
numbers
i dunno where you got your info but ive had some serious people check them and they are legit as well as California CHP cleared them i also have several spare 47 cases all titled and legit according to CHP as if any of you know you dont sneak anything by them!!!!!
Listen and learn
ALL KNUCKLEHEAD WITH 5 DIGITS AFTER THE MODEL NUMBER EXAMPLE 47EL12704 IS OUTSIDE US SALES, WAS BUILT BY HARLEY FOR EXPORT, 4 DIGITS AFTER THE MODEL NUMBER EXAMPLE 47EL3452 IS MADE AND BUILT FOR THE US MARKET. I HOPE THIS HELP YOUR HEADACHES.
Some possible food for thought on this number issue. I am not saying this is the case but I will relate a simuliar situation. I worked a job that was built for the nation of Iraq. The equipment was tire making machinery. All of the machines we manufactured were serial numbered regardless of where they were meant to be delivered. The serial numbers were done in sequence starting from the first to the last. This particular batch of machinery was on the loading dock awaiting shipment for many months. Desert Storm came about and the machinery was held by the Fed. Since payment was not made in full for all of this machinery, the equipment was returned to us three years later when the bureaucrats decided who rightfully owned it all. We did not sell any other machines of this design after building this batch so the serial numbers started over again with a different sequence of letters and numbers on the newer models. My point is....Our serial numbers stopped on the last machines prior to the Iraq sales because the numbers issued on the eqiupment, meant for Iraq, was stricken from the books as a sale when the Fed sanctioned Iraq. This equipment was later sold and the original stamped serial numbers were the identifying marks that were used. Could this case be a simuliar situation ?? Pa
No,
Think about it. Did H-D know exactly how many bikes they were going to build ahead of time so they could assign 5 digit numbers to exports? Production figures show 13,000 bikes were produced. That is a 5 digit number.
If you read his post he says export. Do you know where export is? Anywhere outside of the USA. Canada, Mexico, Alaska in '47, and any other place in the world.
The different thing about Export Bikes is that they were painted Olive Green.
No,
The Numbers
I had a 48 Pan which was Export that had a 12XXX number on it. It came from Guatemala and had a Kilometer Speedo too. You think they made more than 12000 units of the 48 FL ?? that year? And by the way "4 HD" on the TC (argh) stands for EXPORT.
The factory production figures for the '48 Panhead show that 12,924 Panheads were built. Add 1001 to that and you have the engine number range of 1001-13925. Your #12XXX number is well below the total units built.
It is better to base your posts on available information than it is to assume. We all know what happens when you assume.
5 Digit Production Numbers
Mr. Haynes, what i was saying is, that the 5 digit production number Panhead that i hadWAS an export model so the company could indeed make a difference between domestic and export production just as they make today!!
I agree with Chris.
It was like that in any of the early years, If production exceeded 9000 of a type (say overhead valves), any bike made after 9000 would have a 5 digit number its also likely that some of these bikes would have been exported, so as production of 48 pan heads exceeded 9000 then its more than likely you would find a 48 pan out side of the US . But you would probably find more with 4 digit numbers.
If you use the logic that 5 digit numbers could only be used on export bikes where are all the 5 digit knuckle heads built before 1946.
There are plenty of examples of genuine export bikes that don’t have 5 digit numbers.
Pete.
Pete.
