Board index Flathead Power-Technical Questions, Answers, and Suggestions Knuckles emergency fix for intake maniflod nipples
The correct method isn't always an option. A group of my buddies are headed to Hayward, Wi. for their annual "Boys Weekend" tomorrow. One of the guys found trouble with his intake manifold on his '47 FL. Seems as though the threads on the nipples are a little weak. The builder should be spanked for letting that go. Anyway, the question is what type of smoowie can he use to seal them to get him by for the week end? The real fix of course is to replace the nipples. Time and availability doesn't make that an option if he is to make the run. He is leaning toward green loctite. Any other short term solutions?
Smoke 'em till the wheels fall off!
Post Thu Oct 03, 2002 2:32 pm
Green Loctite might make it a little rough to remove when he wants to fix it later.
Go red and use some "smoowie" on the flange outside the threads for sealing......
Got the rocker yet?
Post Fri Oct 04, 2002 2:49 am
The Loctites are not gas-proof.
If not J-B Weld ,(but not the Kwik-Set type), then my next choice would be a urethane metallic paint that would wick into the threads.
When it comes time to remove and replace the nipple, check out my simple tool suggestions at http://virtualindian.org/11techleaktest.html
[This message has been edited by Cotten (edited 04 October 2002).]
Post Fri Oct 04, 2002 3:11 am
don User avatar
John,
Hate to sound like a Plumber, But You might try this stuff.
Here is some SPEC's http://www.xpando.com/pjc.html
Locally at a good pipe supply.
don
Post Fri Oct 04, 2002 8:59 pm
Duct Tape?
