manifold nipple
hello everyone, i'm having an problem with the intake port on my rear head. the threaded area of the head where the manifold nipple threads in at are badly damaged, the place where the rivet was orginally set had been broken off and then repaired (glued together) with some type of epoxy . the front head manifold nipple is still intact,and i want to use the orginal intake manifold. i plan on getting an replacement manifold nipple and locite it in place when i fit the intake manifold,and try to avoid setting another rivet. i'm not sure on which locite to use or if i should use some type of epoxy,i think that the locite would help seal the threaded area, but not sure it will hold up to tighting and untighting of the manifold nut after its been in use. i would appreciate your help on this fix.
