Knuckle Repro's ?
Can anybody give me the complete skinny on a fully assembled knuckle reprodution. I have talked to FHP florida and Don's custom cycles in Oregon. Both seem decent but i want the motor to be setup correctly, i don't want to be sorting out problems later. FHP assembles their engines in house, Don's uses i believe Accurate Engineering to build his. Is one better that the other? Also what is the largest displacement engine i should consider, i'd like to go to 103" if possible, Don's says he can do 80 to 103", FHP pushes the 74", i'd like the motor to be setup for low compression, any suggestions? THANKS, Don.
