Rocker arm endplay
I don`t seem to have any end-play after I tighten rocker shaft nuts on heads.
I did a mock up with the shafts tight in box ,and spacers and washers tight against shoulder on other end. Seems to be enough end play. When I install on heads and tighten up ,end play is gone. I even tried without rubber seal ,zero end play and binding.
Could this be because the tins are slightly distorted and rubbing on thrust washers?
Has anyone else ran into this ? I was going to grind about .010'' off end of rocker arm ,but first I`ll wait for some replys.
Thanks in advance guys.
