Valve guide tolerance?
ncmc47
Post Wed Sep 01, 2010 12:56 pm
What is the proper interference fit between guides and the head? All I could find in the manual is "tight." Surely someone has figured out a more scientific method than that.
TIA
Steve
It's a hard life if you don"t weaken.
wilko
Post Wed Sep 01, 2010 6:29 pm
Re: Valve guide tolerance?
Cast iron guides in cast iron on any application about 1 / 1/2 to 2 thou interference fit.
Post Fri Sep 03, 2010 7:45 am
Sounds about right, and they should be re-sized after insertion since some crushing is normal.
