Board index Flathead Power-Technical Questions, Answers, and Suggestions Knuckles Eating condensers
Eating condensers
Post Sat Sep 26, 2009 2:56 pm
Points don't last long.
Bike already running like crap.
Going to disconnect everything from the rea rof the coil and run a jumper right to the battery.
Maybe there's a short in there....
What a freakin' pain!
Post Sat Sep 26, 2009 9:35 pm
Is the timer top half loose on the bottom half? Do you have a good ground connection between the two? If the breaker base retainer is loose you may be losing ground. Is this a new rebuild or just start happening on a machine that ran fine? You could try your pan base on it to see if it is in your Knuckle set up, seen them insulator pins cause lots of problems.
Previous
