Eating condensers
charlie
Post Mon Aug 17, 2009 7:58 pm
Eating condensers
OK...I put this under Knuckle, but, obviously, it could be for just about any machine with points.
What causes a machine to eat condensers?
6v, 32E, original coil...
It runs fine for a few miles, then pop, bam, cough...with big sparks arcing across the points.
Anybody?
Post Mon Aug 17, 2009 8:35 pm
Re: Eating condensers
charlie wrote:OK...I put this under Knuckle, but, obviously, it could be for just about any machine with points.
Anybody?
Could be defective condensers. What is their country of origin?
charlie
Post Mon Aug 17, 2009 9:12 pm
Probably Taiwan.
But I've cooked several of 2 different styles, and both have been working fine in other bikes.
I was tempted to pick up a Delco at the local NAPA, but they wanted 8 bucks for one, and I didn't want to just cook it.
Post Tue Aug 18, 2009 8:31 am
You can't just use any condenser. If the condenser has too much capacity it will ruin the points. The same will happen if the condenser doesn't have enough capacity.
charlie
Post Fri Aug 21, 2009 9:33 am
I was using the replica ones from Tedd with the stud on the end when they started to get eaten.
Then I switched to a late pan/shovel (6-cyl Chevy) one, and it worked for a little while.
What are y'all using?
Neil74
Post Fri Aug 21, 2009 12:04 pm
At the risk of being wrong again, I have allways gone under the assumption that a condenser can go bad. If you keep burning condenser's the coil is also failing. Has allways worked for me on bikes an Fords but probably just my luck:)
Post Fri Aug 28, 2009 8:39 am
Sounds like good advice Neil. Although I sure wouldn't trust a capacitor from Teds either :lol: Being stubborn I would probably have bought the Delco one first, only to find out the coil's the culprit :(
Neil74
Post Fri Aug 28, 2009 11:48 am
I've allways used 6 cylinder Chevy points and condenser, and I use the same condensor for Harley, Indian 6-volt or 12 volt :roll: Of course now that I know thats wrong.... I'll probably continue doing it untill I experience a problem :lol:
woody
Post Fri Aug 28, 2009 7:09 pm
I don't know if it works the same for HDs, but on Chevys if you wire the primary side of the coil backwards, they will eat condensers.
Post Fri Aug 28, 2009 8:04 pm
Chevy points won't fit a Knuckle timer.
Neil74
Post Fri Aug 28, 2009 10:36 pm
You're right Chris, I'm running a Pan base plate. I had a bad miss an sometimes she wouldn't start for days, I found the insulator on the Knuckle points pin was spinning an intermittently shorting out. Tried all kinds of ways to reseal it but gave up an run a Pan base instead. Are there rebuild kits for these pins available now?
Kurt
Post Sat Aug 29, 2009 6:43 am
Neil74
Yes.........
http://tinyurl.com/lgrjxo
Kurt
Post Sat Aug 29, 2009 7:37 am
That's nice to know. Back when I fixed mine, I used the plastic part of a "red" crimp connector. drilled the rivet, slipped it on, soldered the top washer back on. I hate doing things the hard way.
Neil74
Post Sat Aug 29, 2009 3:00 pm
Nice to know you're making them now, good thing I allways save the old parts, I'll have to order some:)
Post Sat Aug 29, 2009 8:21 pm
Sorry, double post! :oops:
Post Sat Aug 29, 2009 8:22 pm
I always do a ten minute modification on my Knuckle/Flathead timer bases to run '70 up shovel points in my bikes. Cheap and easy to find. I have also set a bunch up to run the really good Bendix points but they are hard to find now.
charlie
Post Sun Aug 30, 2009 10:46 pm
OK...I'm going nuts.
New coil...well...different coil, anyway...
New condenser (Delco)
Checked timer base for good ground.
Checked pivot pin for isolation.
Checked points condenser terminal on timer base for isolation.
Checked timer-to-coil wire for short/grounding.
Fire it up.
Big ol' sparks flashing out of the points.
I'm going to bed.
It can't be far off.
There's only a handful of parts to check out!
Neil74
Post Mon Aug 31, 2009 8:37 am
Try a new coil, or a used coil that you know just came off a running machine. The insulator pin is a pain in the rump to check if... it's not cracked bad. I had a friend kicking my bike over in the pitch dark to see exactly where my arc was originating, when it would spark sometimes an not others I put a magic marker dot on the insulator at the spark site. Thats when I discovered the insulator was spinning an exposing the points to the crack. The crack was not visible and I could not spin it with the points removed, under point movement it was obvious it was spinning cause the index mark turned:) If you can borrow another Known good Distributor base with points an condensor you could swap it out to see if that is your problem.
charlie
Post Mon Aug 31, 2009 11:06 am
Oh, yeah...when the problem started, I checked the pin and insulator...which came off in 2 pieces.
I repaired that with the Colony kit assuming that the problem would CERTAINLY be solved....
charlie
Post Sat Sep 05, 2009 2:04 pm
OK...new points and condenser AND coil.
The bike is running great, like it used to, but there is still a lot of sparking at the points; I wonder how long they can last.
I can't see a bit of sparking at the points of my Pan.
Anybody else have considerable sparking at the points, but the bike runs OK?
Any way to gauge an acceptable amount of sparking at the points?
