case joint is leaking
Took off the protective bottom cover an found the leak
In cold condition every hour a drop comes down (sae60).
Though I don't like the idea ....I don't want to dissamble everything again, and plan to put a good sealer on , what would you suggest?
It's a small leak zone ,1/2 inch long, one inch behind the front bottom bolt..
