Board index Flathead Power-Technical Questions, Answers, and Suggestions Knuckles m35 venturi
m35 venturi
Post Wed Jul 15, 2009 7:03 am
I have an m35 on a 47 knuckle, 74 cubic inch. Is there any advantage to using an m74 venturi in the m35? Is there anything that has to be done other than swapping the venturi?
Thanks,
Paul
Post Wed Jul 15, 2009 9:38 am
Sure - more power.
it's a drop in, but you should be using the 5 hole M45 or M75 main nozzle (27331-41).
I show a 9° throttle disc for the M45 but 12° for the M35, so your off-idle response may be a bit soft - try it out.
