Oily Knuckle!!!!
please any info would gratefully be recieved
regards
Cooky(England)
john k. endrizzi wrote:Use fluro viton seals from Ed Rowe.
John
ncmc47 wrote:Also check that the lifters don't have holes in the top of the body (Eastern). I fought that perticular problem for quite awhile. I also drilled holes (.060") in allen plugs and tapped all three fittings going to the heads: at the advise of S&S tech. I would replace rocker arms with Flatheadpower, since they don't have the spirial cut internally that V/Twin added. On my lifters, I set in a small can of water, with ground clamp to the neck, and tacked the holes shut. The main thing is to not let them get too hot. The top is braised to the body prior to heat treating. Hope that helps some.
Steve
COOKY6660 wrote:ncmc47 wrote:Also check that the lifters don't have holes in the top of the body (Eastern). I fought that perticular problem for quite awhile. I also drilled holes (.060") in allen plugs and tapped all three fittings going to the heads: at the advise of S&S tech. I would replace rocker arms with Flatheadpower, since they don't have the spirial cut internally that V/Twin added. On my lifters, I set in a small can of water, with ground clamp to the neck, and tacked the holes shut. The main thing is to not let them get too hot. The top is braised to the body prior to heat treating. Hope that helps some.
Steve
I do have holes in the top of the lifter blocks, but arnt they to let the oil escape to cam chest? I dont understand, why are you welding these holes shut and for what reasons please? Ive not heard of this before.
regards
cooky
cane wrote:What caused the excess lubrication?
