Knuckle frame
51elpan
Post Fri Sep 12, 2008 4:04 am
Knuckle frame
I've got a knuckle frame with a pan motor in it out of curiosity I'd be interested to know what year the frame is, could any of you gents help out please?
BrentCross@Bronko's
Post Fri Sep 12, 2008 5:06 am
Re: Knuckle frame
Post a pic - can't do much without a picture especially if it has been modified a lot.
Post Fri Sep 12, 2008 9:55 am
Re: Knuckle frame
A Pan engine won't fit in a Knuck frame without serious modification.
51elpan
Post Sun Sep 14, 2008 2:42 pm
Re: Knuckle frame
Can't get the pictures to take, can send them on to anyone who can help. While I'm on can't find much info on the S&S 103" knuckle engine is it high compresion, am I going to be able to kick it and will it blow my 4 speed apart?
Post Sun Sep 14, 2008 4:40 pm
Re: Knuckle frame
51elpan wrote:Can't get the pictures to take, can send them on to anyone who can help.
Send them to me at,
hd36knuckl@aol.com
51elpan
Post Tue Sep 16, 2008 1:26 pm
Re: Knuckle frame
Done, did they come through ok?
Post Tue Sep 16, 2008 8:48 pm
Re: Knuckle frame
51elpan wrote:Done, did they come through ok?
I haven't seen them.
Post Wed Sep 17, 2008 5:03 am
Re: Knuckle frame
If Chris can't receive them, try sending them to me. Pa
vtwinrebuild@yahoo.com
51elpan
Post Wed Sep 17, 2008 2:30 pm
Re: Knuckle frame
Thanks Chris and Pa sent them again, if you don't get them would you be kind enough to mail me at ttboy1962@hotmail.co.uk and maybe it'll go as a reply
Post Wed Sep 17, 2008 3:18 pm
Re: Knuckle frame
I received the photos. But I can't see the seatpost tube behind the rear head of the front motormount clearly in any of them.
51elpan
Post Wed Sep 17, 2008 4:47 pm
Re: Knuckle frame
I'll take some more tomorrow, the seat tube is bashed in to clear the rear head though.
Post Wed Sep 17, 2008 5:21 pm
Re: Knuckle frame
51elpan wrote:I'll take some more tomorrow, the seat tube is bashed in to clear the rear head though.
To be done correctly, if there is such a way to goober a frame, the front motor mount need to be lowered. The Panhead front mount is lower than the Knuck and the mounts won't sit flush of the frame unless the front mount is lowered.
Post Wed Sep 17, 2008 7:05 pm
Re: Knuckle frame
I received them as well. Let me know which you don't want on here. I'll remove them for you. Pa
Jerry Wieland
Post Thu Sep 18, 2008 3:44 am
Re: Knuckle frame
Later 41 to 45. Jerry
Post Thu Sep 18, 2008 8:50 am
Re: Knuckle frame
Jerry,
If you will notice this is a brazed frame. Brazed frames came in during 1944.
Post Fri Sep 19, 2008 6:31 am
Re: Knuckle frame
More pics....
Post Fri Sep 19, 2008 10:09 am
Re: Knuckle frame
Notice how the front of your front motor mounts are raised off the frame? They are incorrectly sitting on the mounts and will eventually break them.
51elpan
Post Fri Sep 19, 2008 3:30 pm
Re: Knuckle frame
Is that because it's a pan motor?
indianut
Post Fri Sep 19, 2008 7:31 pm
Re: Knuckle frame
51elpan wrote:Is that because it's a pan motor?
No....it's because it's a Knuckle frame!
Post Fri Sep 19, 2008 7:35 pm
Re: Knuckle frame
The front motor mount on a Pan is lower than a Knuck. So when you stuff a Pan Motor into a Knuck frame the mounts don't sit flush.
