1947 BULL NECK FRAME
DANPATCH
Post Sun Jul 27, 2008 12:03 pm
I HAVE A BULL NECK FRAME THAT IS BRAZED . I THINK SOMEONE HAS CHANGED THE NECK.DID ANY BULL NECK FRAMES COME BRAZED LIKE THE 1941 -1945
Jerry Wieland
Post Sun Jul 27, 2008 8:12 pm
Re: 1947 BULL NECK FRAME
I do not believe that the 30 degree frames ever came with brazed in sidecar loops but they are brazed elsewhere. If it is brazed at the loops is it possible that you are confusing a 41 to 44 29 degree frame (which has a slightly oval neck) with a ealy 30 degree neck which is more oval. It can be easily confused.
Jerry
Post Sun Jul 27, 2008 10:22 pm
My 1947 factory photo shows a brazed neck.
DANPATCH
Post Thu Jul 31, 2008 8:43 am
THANKS
Jerry Wieland wrote:I do not believe that the 30 degree frames ever came with brazed in sidecar loops but they are brazed elsewhere. If it is brazed at the loops is it possible that you are confusing a 41 to 44 29 degree frame (which has a slightly oval neck) with a ealy 30 degree neck which is more oval. It can be easily confused.
Jerry
