Board index Flathead Power- General Announcements and Various Subjects Motorcycle Trivia compensator nuts
compensator nuts
Test your knowledge or someone else's with trivia questions about your favorite subject. Let's be realistic with the questions so everyone has a chance at answering them.
Post Sat Aug 30, 2008 1:01 pm
I have a -55A compensator and I'm wondering what is the difference btwn the -55A and the -65 and later comp other than the absence of a zirk fitting in the latter, I know the sprocket shaft is longer from '64 to '65 and later but the protrusion after the spacer seems the same. this is for a '66 shovel. is the length the same and will the -55A comp work on the '66
frank
Return to Motorcycle Trivia
