Threaded bolt??
George Greer
Post Tue Feb 01, 2011 12:09 pm
Threaded bolt??
Hey fellas,
Where could I get a couple of threaded aluminum bolts that is the same thread pitch and size for the studs that hold the engine cylinders to the case?
I need this just to fill in the holes, and then cut them off flush, then redrill the KH cylinders base mounting studs, using a gasket as a template?
Thanks.
George
Tim The Grim
Post Tue Feb 01, 2011 12:59 pm
Re: Threaded bolt??
You could get a 3 foot length of 3/8-16 Aluminum Threaded Rod from Amazon.com through MSC and they probably ship to Germany. cut what you need and save the rest for another endeavor.
http://www.amazon.com/Made-USA-AT038C03 ... B0025PP0Y4
Tim
'54 KHK since 8/70
'76 XLCH since 4/85
'97 Valkyrie since 10/96
Post Tue Feb 01, 2011 5:11 pm
Re: Threaded bolt??
i cut the thread in to a round aluminium bar, when i did mine
Post Tue Feb 15, 2011 1:45 pm
Re: Threaded bolt??
My Dad made mine years ago before I got my own lathe. Put a screwdriver slot in the end, then turned it down to 3/8" and cut the threads. That way I had a way to easily thread it in tight, then cut it off flush.
Post Tue Feb 15, 2011 6:23 pm
Re: Threaded bolt??
similar to you DD ,but i screwd it below the deck by 1/8' and then had them welded both ends
George Greer
Post Tue Feb 15, 2011 9:42 pm
Re: Threaded bolt??
Well.
I just got a piece of 7075T6 round bar .500 dia, 6" long,
Turned about 2" down to .375 on my lathe, then my trusty Craftsman tap & die set came home from work yesterday and I got it threaded,...
More work to do
George
Return to Shoot The Bull
