Board index Flathead Power-Technical Questions, Answers, and Suggestions Servi-Cars Rear axle freeplay..?
Post Mon Mar 17, 2008 11:39 am
after inspecting and cleaning my axle, it must be assembled again.
according to my servicarmanual, axle-end freeplay must be between.003 and .005.
in my situation left .009 and right.0011. (1952 hydraulic brake) (the axle ends can move sideways,pushing on left-,than right comes out a little.push right will poush left out
the lock-rings are a little worn on the inside (on side of differential-gear spacer) i think thats were freeplay comes from.
when i rotate the axle-half-lockrings (inside facing outside) there is no freeplay or moving sideways.
my lockrings are .125 thick, the standard version. if i put new ones in my rear , there will be NO freeplay.
what are my options ? order.125 and make them .003-.005 thinner? or assemble with 009 and 0011
anybody ideas?
Return to Servi-Cars
