Fri Feb 10, 2006 7:46 pm by Pa
Brewski...they made plenty more of them from 1941 up to 73, not to mention the over 100 plus thousand Solos. These systems are built for easy conversion of the kick start only Servi-Car models and will allow an owner to quickly return his bike to original specs if he so wishes too. Those who own earlier model Servi-Cars with 6 volt systems do have to convert them to 12 volt but again...it still allows them to return to the 6 volt system if desired. Of course they need to keep a hold of all their original parts in order to revert back. The e start is mainly for those who can no longer kick a bike over. Even the 45" can be quite a task for the elderly or mamed. For the bobber person who is used to a button start and wants the look of an early bike, it fits right in for him also. For the 64-65 Servi-Car model owner, it is a refreshing reliable change for them from their existing unreliable early e start system. By the way.....HD made a fix for the sticking pinion in late 65 due to that irritating and sometimes dangerous problem but it wasn't a very good one. It consisted of a spring steel bent wire, screw, and a drill bit, for installation of it but the operator still had to manually push on the spring steel wire to help operate the pinion. This only kept his fingers out of the way. It made for a mickey mouse fix though, so HD came out with the 66-73 system which permanately fixed the early systems short falls. Sales will really take off for the system as soon as the Solo model is completed. Inquires on it have been super heavy. The original 66-73 Servi-Car models are well sought after now and most of them are in need of a total starter system rebuild. Now they have a source for those components. They have a source for the complete units also. Pa
