Will these pistons 22251-52A K-model, KH fit in my engine?
Activate
Post Mon Jan 23, 2006 3:44 pm
I have a servicar with this engine code 50G2380.
Will these pistons fit : 22251-52A K-model, KH '52-'56.
Thnaks and greetings in advance,
Erik.
Post Mon Jan 23, 2006 6:02 pm
Yes, with either a base shim or a pop-up relief.
Post Mon Jan 23, 2006 8:36 pm
hi erik, were did you get those pistons and how mutch please ,if you dont me asking and also what size rings are fitted. cheers jib
Activate
Post Mon Jan 23, 2006 11:54 pm
http://www.jwboon.com/index2.php?conten ... del/Page_6
60 Euro , Ihave the .010.
Greetings,
Erik
Post Tue Jan 24, 2006 4:30 am
hi erik, are you sure that tiawanesse pistons will be ok?
im goner email them and ask for the the ring depth[thicknesses] thanks jib
Post Tue Jan 24, 2006 12:32 pm
$73.75 each!!
Same piston from KNS Cycle $40. each:
http://victorylibrary.com/kns/parts.htm#Pistons
Post Tue Jan 24, 2006 12:59 pm
i hear whar you say panic,but im in england and its cheaper/easier to get from holland than US, import tax, theres also the minimum postage charge and $50 and i'll refund the difference stuff i dont understand on the bottom of the order form,
emailed jwboon[rene] today and has the pistons in old and new style rings ,
there is stuff i would like from kns like the oversize inlet valves ,skirt oiler kit etc ,reground cams,but cant get my head around paying someone more and having a refund .
if some one could explain then it wouldnt be a problem
cheers jib
Activate
Post Tue Jan 24, 2006 1:04 pm
Wich rings are beter the old style or the new style??
greetings,
Erik.
Post Tue Jan 24, 2006 1:26 pm
the new thinner type
Post Tue Jan 24, 2006 5:03 pm
He won't know the exact postage until the box is completely packed, made, closed and weighed at the Post Office. I'm sure you can understand they don't trust his scale, and he doesn't want to make the trip twice just to give you the exact postage. There's extra to allow the heaviest the box is likely to be - you get the extra back if it weighs less.
Post Wed Jan 25, 2006 5:00 am
that it explains it thanks panic
cheers jib
Post Wed Jan 25, 2006 10:25 am
The KNS Cycle order form should be easier to understand now:
http://victorylibrary.com/kns/k-fororder.htm
Return to Servi-Cars
