'64 servi car chain oiler
browncr
Post Tue Aug 27, 2013 11:18 am
since there is such an abundance of knowledge here can anyone provide any info of how to stop the rear chain oiler fro dripping so much oil?
all i see is a copper tube sticking out of the engine and a LARGE puddle on my drip pan...
same goes for the primary chain dripping also.
this makes a real mess on exhaust pipe and throws oil all over everything.
BTW, engine and tranny run very well...
Post Wed Aug 28, 2013 11:05 am
Re: '64 servi car chain oiler
If you follow that tube back to the oil pump you will find an adjustment screw. Gently snug it down to cut off the oil flow and lube the chain by hand. DO NOT TIGHTEN THIS SCREW! If you do or if it has been tightened the seat will be damaged and you will lose all control.
Return to Servi-Cars
