Board index Flathead Power-Technical Questions, Answers, and Suggestions Servi-Cars 1972 servicar
1972 servicar
Post Thu Feb 16, 2012 12:58 am
is their a kick start kit for the electric start transmission thanksv
Post Thu Feb 16, 2012 8:43 am
No....you need to replace the electric start case with a kick start case. You also need several of the kick start components the electric start type does not incorporate, both internal and external components. Extensive machining can be done to convert an electric start case to a kick start but it is much easier and less expense to just find a good kick start one, rather than to go through the machining process and parts change over.. However.....you can convert a kick start to an electric start fairly easily.
Post Sat Feb 18, 2012 1:18 am
thanks very much
Return to Servi-Cars
