Thu Feb 16, 2012 8:43 am by Pa
No....you need to replace the electric start case with a kick start case. You also need several of the kick start components the electric start type does not incorporate, both internal and external components. Extensive machining can be done to convert an electric start case to a kick start but it is much easier and less expense to just find a good kick start one, rather than to go through the machining process and parts change over.. However.....you can convert a kick start to an electric start fairly easily.
